cheap bypass for D3?
By squig29 · May 06, 2008in General💬 24 posts👁️ 4,490 views
Posted May 06, 2008 · 05:28 UTC#1
I have an 07 Dodge Nitro & have been simply pulling the park brake up 1 notch. It doesn't grab until the 3rd notch & I'm wondering if anyone thinks this will still cause unnecessary wear on my park brakes? :twisted:
Posted May 06, 2008 · 06:39 UTC#2
i dont really know but i think its not good for it...
Posted May 06, 2008 · 07:26 UTC#3
Why don't you just do the bypass described in the hacks/mods section and not worry about your e-brake anymore?
Posted May 06, 2008 · 07:47 UTC#4
I haven't done the bypass because I thought using the park brake would be undetectable by the cops. When I see a cop I put the handle down & everything operates the way it normally should. Kind of a fool proof bypass... as long as there is no extra wear on the brake.
Posted May 06, 2008 · 10:30 UTC#5
no cops are going to get in your car and inspect your unit. the only way a cop is going to know anything, is if you pull up next to one with a dvd playing
Posted May 06, 2008 · 12:59 UTC#6
Actually, unless your crazy enough to play a DVD while driving in front of a law enforcement officer, there is pretty much nothing that can happen. If you turn the unit off before than can see it playing, they would have to have a warrant to be able to "investigate" your unit. Cops are not allowed to just go into your vehicle without permision unless in the seach or dangerous weapons within your imediate vicinity, and then they can only look for what is in plain site and easily accessible, for example, no opening the glove box or any other boxes etc in your vehicle, that would require a warrant. In case your wondering where I get this info from, I was a Shift Commander (Rank of Lieutentant) for my local Sheriffs office before I ended up with a family and the salary was not cutting it.
Posted May 06, 2008 · 14:05 UTC#7
IF your parking brake is adjusted correctly, even at the first notch it would be applying at least a slight pressure on the rear brakes... whether your car uses the rear pads for the parking brake, or has a separated drum system for the parking brake... whatever. It doesn't really matter. If your brakes are in proper working order, you shouldn't do that. I'd be more concerned about ruining brake pads/shoes/rotors/drums/etc.
If you're that paranoid about cops hauling your ass to jail over a video bypass, just do the bypass... and put a toggle switch on the wire.
Posted May 06, 2008 · 22:37 UTC#8
thanks for ll your input... you guys kick ass. I will most likely do the bypass with the toggle switch.
Posted May 07, 2008 · 03:19 UTC#9
Plus doesn't your vehicle make the god awful "ding ding" sound when you have your parking brake on and the car in gear? I can't imagine with all the crap in todays cars that it wouldn't. Another thing, anyone who lives in the cold knows that with a parking brake on they have a tendancy to freeze in winter and lock the brakes. I learned this the hard way.
Posted May 07, 2008 · 06:45 UTC#10
it doesn't ding continuously, only once each time you start moving, (if music is turned up loud enough you don't hear the ding).
for the record, I've had my Nitro in to the shop a couple of times because the park brake wasn't holding the truck on even the slightest of slopes. It still doesn't do it's job properly & that's why I started using the "cheap bypass" in the first place.
I will do the proper bypass though.
Posted May 07, 2008 · 10:57 UTC#11
The factory navigation unit in my Mitsubishi Lancer does pretty much everything my D3 in my MR2 does with the bypass, except play DVDs. Unless you're watching a movie while driving and a cop sees you doing it, you're not going to get in trouble. And by then it'd be too late to pull the p-brake anyway.
Also, pulling the p-brake by itself won't give you full fuctionality of the bypass. Keep in mind that when you ground the p-brake wire, it's as if the p-brake were being pulled all the time anyway. To successfully perform the mod, however, you also have to modify the pin-out configuration on the harness to change the location of the mute wire. It's an absurdly simple mod and you need ZERO electronics experience to do it. I highly reccommend it.
Posted May 07, 2008 · 23:36 UTC#12
I think you all have convinced me.
thanks for your help
Posted May 10, 2008 · 19:26 UTC#13
Don't listen to them. I just got out of jail for bypassing my D3. I was watching a DVD (Jungle Book) on my way to work. The bastard saw me rockin out to Disney and pulled me over. I couldn't disconnect my ground and reconnect my parking brake wire in time. He made me scroll through the menus and that's all he needed. 60 days in jail and a $10,000.00 fine.
Posted May 10, 2008 · 20:26 UTC#14
BS!!! Next you'll tell us you narrowly escaped the death penalty! :roll:
I assume you were in Nebraska since you were going to work...
Nebraska Code - Section 60, Paragraph 60-6,287 provides that having a viewing screen placed so that it is visible to the driver while operating the vehicle is a Class V misdemeanor. Maximum penalty for a Class V misdemeanor is $100 with NO imprisonment. There is no minimum penalty.
Laws in the other twenty states that currently ban video in view of the driver are substantially similar.
Perhaps there's something else about this traffic stop that you neglected to mention?
Posted May 10, 2008 · 23:16 UTC#15
Maybe it's because you were driving to work drunk?
Posted May 11, 2008 · 01:29 UTC#16
hey after you have done the bypass, do you ever get the screen that says something to the effect of "motion detected" & you can no longer see the video? I haven't done the bypass yet but on occasion using the park brake this screen will come up.
Posted May 11, 2008 · 02:29 UTC#17
Of course it's BS. Why would I be watching the Jungle Book?
Posted May 11, 2008 · 02:32 UTC#18
If you follow the bypass directions found on this forum you will not get that screen.
Posted May 11, 2008 · 08:03 UTC#19
thanks Derf
Posted May 11, 2008 · 08:14 UTC#20
Because you've got a thing for little boys wearing loincloths? :wink:
Posted May 11, 2008 · 14:48 UTC#21
Okay...you really got me with that one.
I was thinking that saying Jungle Book was a cover-up for what you were really watching. Nebraska is one of only five states that not only outlaws video visible to the driver but also the content of video anywhere in the vehicle that is visible from outside. I thought maybe you were watching a porn movie - something like "Jungle Boink"? :lol:
Posted May 11, 2008 · 17:20 UTC#22
That info was supposed to be sealed.
Posted May 12, 2008 · 07:53 UTC#23
I didn't know my own state outlawed the type of video being watched too. I guess I really should pay more attention to the laws that our fine men of the state are passing. Hey at least they raised the gas tax too. Welcome to little Kalifornia. LOL
Posted Jun 04, 2008 · 23:07 UTC#24
just get a toggle switch hooked up to it. :twisted:
