avic d1 clock setting
By bertom2000 · Aug 13, 2006in Problems/Troubleshooting💬 4 posts👁️ 1,762 views
Posted Aug 13, 2006 · 01:39 UTC#1
i have tried setting the clock but the + or - signs dont work on that screen. do i have to ground the emergency brake wire for it to let me set the time? i also get a popping noise when i shut off the car. is this normal with this radio?
Posted Aug 13, 2006 · 06:21 UTC#2
parking brake wire must be grounded. What kind of car do you have?
Posted Aug 13, 2006 · 13:10 UTC#3
2003 kia optima se. by the way, where can i find the vss, parking brake and reverse wires?
Posted Aug 16, 2006 · 13:45 UTC#4
Parking brake is light blue @ the lever, reverse lights are light green under the driver's door sill, and VSS is brown, pin 14 at the diagnosic connector on the right side of the steering column under the dash.
