My old phone was not bluetooth, new one is? how do i make my d3 and phone work together? i found on the phone where to go to make it find another device, so what do i do to the d3 make them hook up?
Got a new phone, how to make bluetooth work on d3?
What kind of phone?
its verizon lg vx8350 or something like that. what does bluetooth mean and what is the d3 capable of?
Bluetooth is a wireless data transmission system that allows your phone to communicate wirelessly with your radio and other bluetooth devices. Im not familiar with the paring process with you phone but it should be outlined in your manual. I think there may also be issues with Verizon disabling bluetooth on there phones. Ill have to do some digging around here to find out. Also try the search function on this site, it works pretty well.
This should cover the phone paring procedure...
Pairing Instructions:
To turn Bluetooth ON, Click Menu-> Settings and Tools ->3. Bluetooth Menu -> Turn On
1. Click Menu -> Settings & Tools -> ->3. Bluetooth Menu -> Add New Device. Your
phone will display a list of any Bluetooth devices that it discovers in range and available
to be paired.
2. Select the name of the Bluetooth enabled device with which you are pairing then press
OK to connect the device.
3. Select YES if the device requests permission to bond with the phone, then enter passkey.
Sometimes Bluetooth enabled devices contain a hard coded passkey. See the car manual for
the passkey.
The D3 end of it is outlined in the manual
that's the part i already knew, sorry i was unclear. i don't have a manual, i did all that with the phone and it didn't find the d3, i need to know what to do with the radio, not the phone. thanks,
Sorry,
When you have it in the BT Tel mode go to Function, Phone Connect, and then touch Search and the D3 should begin searching for your telephone. Once it finds the phone, on the main screen with the six empty "slots" touch and hold number one to register your phone in that slot.
bt tel mode? how do i get there. i went to av menu and i see the bt button, but it is not lit up, i can't press it????????
Do you have the BTB200 Bluetooth module installed, you need that for the bluetooth wireless to work.
Its this...
does anyone know how to transfer contacts from nokias to the avic d3? everytime i try to transfer a contact, the paired connection gets disconnected.
no i don't have that module. that's the problem. anyone know the cheapest place to buy it? and how hard is it to install? i didn't install my d3 but i can install a basic aftermarket cd player.
Ebay, Crutchfield, Local Venders anywhere you please. Installation is about as easy as it can be. Two wires, black (ground) and a yellow (12v constant) which can be tapped into your D3 harness if mounted near, the ip-bus cable, and a microphone. Easy as pie.
