Problem with the flash mod
By Brynwall · Aug 13, 2006in Hacks/Mods💬 7 posts👁️ 1,996 views
Posted Aug 13, 2006 · 18:02 UTC#1
Well, when it first got installed it didn't work while I was driving...
I got it back home and then pulled the unit out. I unplugged the unit (which basicly reset the Z1). I plugged it back in and then the flashing unit worked for a couple of hours.
I noticed that when I was driving I all-of-a sudden got the warning messages that ususally show when the unit first starts up. After that the unit stopped working.
I'm going to try another reset today to see if it works and post the results here.
I read that there is a reset button on the front of the unit so I'll try that first and then set to factory defaults if that doesn't work.
Posted Aug 13, 2006 · 19:03 UTC#2
It was as simple as pressing the reset button on the front with the Stylus pen (or something small enough to press it in). I took my truck for a little ride and had full access to ALL of the functions.
It worked like a charm.
This is an awesome mod DB! I appreciate all of the work that you put into to this device for us all. :) :twisted:
Posted Aug 14, 2006 · 15:39 UTC#3
Do us a huge favor would you? Look at the label on your box and tell us the manufacture date. Thanks!!
Posted Aug 19, 2006 · 01:03 UTC#4
hey brynwall please post your build date, it is on the box along with some barcode. It says MFD and then the month and year, please post as soon as you can, and also others who have not gotten theirs to work, please post your build dates!?!
Anyone who has a July 2006 has their working?!?
I have a July 2006 and i cant get it to work.
Thanks for reply!
Posted Aug 19, 2006 · 21:42 UTC#5
Build date was in May
Posted Aug 19, 2006 · 22:21 UTC#6
What was the warning message? Was it that the parking brake was installed incorrectly? If so, then you parking brake is grounded all the time, don't do that. Remove that from ground and leave it disconnected... then reset the unit again and you will be good to go.
Posted Aug 19, 2006 · 22:32 UTC#7
yeah, i commented in my other thread what happened
