I have XM installed as a factory option. When I install my new F series, can I use the existing XM stuff or do I need to buy anything else to make it work? Thanks.
A question about the F series and XM
Anbody?
You really expect someone to respond in 3 hours? Not everyone spends a majority of the day on the internet like you or I.
I suspect you'll have to get a tuner for it, similar to the Z-series. I say this because it only comes with 1 antenna awhich is meant for the gps signal itself.
Yeah, I do .....even though you were no help, you responded. Trying to build post count or something?
You will still need the Pioneer GEXP920XM tuner
But you may be able to reuse your factory antenna, depending on how much you want to modify the factory wiring.
seems like I was help seeing how whtcrxghst confirmed what I said. All I was trying to say is some people just check the net on their lunch breaks and if I were a company man, that'd be all i check it too. 3 hours isnt enough time for people to check the net.
Thanks for all the responses I do appreciate it.
