NEED HELP PLEASE
By luilui8812 · May 14, 2008in Problems/Troubleshooting💬 22 posts👁️ 2,874 views
Posted May 14, 2008 · 22:04 UTC#1
Hello, first off IM NEW HERE.
i just got my avic-z1 about a month ago, i installed it fine with the bypassed wires and everything was fine. but i then i was testing out something in my brothers car when all the sudden the 12v constant wire touched the ground wire, and the cars FUSE burned after we replaced it, it seems that the subwoofer OUTPUTS dont work anymore. all i hear is MONOTONE bass that doesnt bump or do anything. i got the unit off ebay as factory refurbished so i called pioneer customer support and they couldnt do anything because EBAY isnt a authorized pioneer dealer.
PLEASE HELP, if anybody knows how to repair this please help, i had saved up for this unit for MONTHS only so it wouldnt work properly. :cry::cry:
Posted May 15, 2008 · 12:31 UTC#2
Well...technically it did work properly, you just hosed it somehow. Pioneer should be able to fix it, but it's gonna be at your expense.
Posted May 15, 2008 · 22:41 UTC#3
yea i know they said they could fix it but i would have to pay $200 service charge. but i was hoping someone here might have had the same problem and fixed it some other way. if anybody knows, can they please walk me through it.
Posted May 15, 2008 · 23:12 UTC#4
Since that was your 12v constant wire you lost all your settings.Did you go back in and reset your volume on your sub levels?
Posted May 15, 2008 · 23:26 UTC#5
yea i know, i turned the subwoofer ON and still did same thing, and when i turned it off , BASS was still humming. im more than sure its not the settings.
Posted May 15, 2008 · 23:33 UTC#6
I sorry to say but it doesn't sound good.If its making sound after you cut the sub off then there's a problem.Does everything else work ok? Have you tried resetting your unit?
Posted May 16, 2008 · 02:59 UTC#7
yea i know, even if the volume is ALL the way down, subs still make loud humming "MONOTONE" sound. what do you mean reset? is there a hard reset button? would this might work?
Posted May 16, 2008 · 03:04 UTC#8
OH YEA, and everything ELS works fine. the only thing i havnt tried was the Preamp RCA's which is in the same harness as the subwoofer inputs. that probably doesnt work also hugh?
Posted May 16, 2008 · 04:16 UTC#9
There is a reset button on the bottom left front of the unit .You will need a pen or safety pin to press the button in.
Posted May 17, 2008 · 13:55 UTC#10
i just got my avic-z1 about a month ago, i installed it fine with the bypassed wires and everything was fine. but i then i was testing out something in my brothers car when all the sudden the 12v constant wire touched the ground wire, and the cars FUSE burned after we replaced it, it seems that the subwoofer inputs dont work anymore. all i hear is MONOTONE bass that doesn't bump or do anything. i got the unit off ebay as factory refurbished so i called pioneer customer support and they couldnt do anything because EBAY isnt a authorized pioneer dealer.
Reading your post it's hard to figure out what you did. From what I gather you:
1. Installed your Z1 in YOUR car. Worked fine.
2. Uninstalled your Z1 from your car and re-installed in your brothers car?
3. Touched the 12+ from the car to the Z1's ground wire?
4. Re-installed the unit in YOUR car, and now the subwoofer OUTPUTS (you said inputs, but there is no sub-in on the unit) creates a humm.
In a subsequent post you said you're not using the RCA's, correct? So you are using the violet and violet/black wires for sub signal and those are directly wired to the sub with no external amp, correct?
Posted May 21, 2008 · 20:09 UTC#11
all the steps you mentiond are correct. except the part where im not using the rca's correct. i AM using them correctly, i have them connected to the subwoofer OUTPUT(sorry for the mistake of putting input)from the radio, to an EXTERNAL AMP (hifonics). then from amp to bass speakers.
What im using now just to get through, is a "Line out converter" which is working fine, but i obviously cant control bass through radio anymore so it doesnt sound AS good.
Posted May 22, 2008 · 02:44 UTC#12
I wasn't saying you weren't using them correctly (how does one use them incorrectly? They're pretty self explanatory, right? :lol: ). I was trying to find out if you were using them at all.
So your getting a clean signal from the line level converter to the amp? So, line converter from rear speaker lines to the amp, correct...I mean, right?
If your getting a clean signal with the converter from the rear speakers to the amp then your unit most likely has a blown circuit on the sub output OR maybe you've got a bad RCA cable OR something touching back there that shouldn't. I know my unit is CRAMMED into my dash.
If it were me I'd do a hard reset, reconfirm all connections (make sure nothing is touching that sub-output and replace the RCA cable and try again just to be sure). I've done lots of installs where I've had ground loop or other interference problems after install; gone back in to look for the problem, not find anything, reinstall, and the problems gone. Murphy's Law.
If none of that works and your not satisfied with the line converter (I wouldn't be either) then the only option is to send her back to Pioneer.
Good luck, I hope it works out.
Posted May 22, 2008 · 04:36 UTC#13
Thanks for the reply. it definetly has to be a blown circuit because my rca's are fairly new, and i made sure nothing was touching when i installed it. i know what you mean when you said everything is crammed in. but i didnt have the radio IN its slot when i was trying to figure out what was wrong.
im going to do the hard reset and HOPE that it works. if it doesnt ima try and get either a repair or exchange from the person i bought it from.(ebay). wont be easy... and if THAT doesnt work, ima try and repair it myself, i have pretty good soldering skills. you think it would be hard finding the blown circuit?
Thanks for ALL the advice.
Posted May 22, 2008 · 07:21 UTC#14
It would be extremely hard to find a blown circuit unless you know your way around a board,know how to use an oscilloscope and know what part of the board controls the subs.Then you would have to unsolder computer solders ,in sometimes very close confines inwhich some components cannot receive a lot of heat.Excessive heat causes damage and you can't always attach a heat sink.All blown circuits don't aways show burnt areas either.So unless you have mad electronic skills I would get it repaired.
Posted May 22, 2008 · 11:31 UTC#15
+1 8)
Send it in for the pro's to fix it, unless you're a board level electronics nut :!:
Posted May 22, 2008 · 23:34 UTC#16
well if i dont get to exchange unit, then ill have to save up to send it to pioneer, repairs are $200 it sucks but at least its not like buying the unit all over again
Posted May 23, 2008 · 01:08 UTC#17
OUCH! Had mine professionally installed for that very reason. I'm just not comfortable inside the dash of my truck. although I believe I'm about to order an LED bulb replacement kit and gauge kit as well. That should look pretty tight when I'm done.
I say let the gurus fix it and have the sucker installed so it doesn't happen again. at least if they fubar it then they will replace it.
Posted May 23, 2008 · 02:09 UTC#18
yea i know, but i have been doing stereo installations as well as other A/V electronics for about 7 years. but everyone has bad days. if your replacing the bulbs on the CLUSTER LIGHTs my cardomain might help you. i did it myself for my blazer, check it out and tell me what you think.
http://www.cardomain.com/ride/2571095/6
Posted May 23, 2008 · 03:04 UTC#19
Very nice dash,Good work!
Why don't you take your unit to a shop and see what they charge to check your unit and sub before you send it to Pioneer?
Posted May 23, 2008 · 03:32 UTC#20
Oh man! That's PIMP! I think I'm too old to use that word now, but sometimes it just fits. I like it. That's exactly what I'm after. I've found a few forums that have some helpful hints for my dash mod. I even found a dude up in Ontario where the 15 and the 10 meet that does the mod on Tundras. But I do love the look. Imagine how good that will look with all blue interior lights including the console lighting. I will go with white LED lights for the door and map lights though.
Posted May 23, 2008 · 04:16 UTC#21
i might do that. to see how much it would cost because everytime i go there to check prices their ridiculously overpriced. a z2 unit is like 1800 and z3 is around 2200.
and i DID replace ALL my console light, its on page 4
http://www.cardomain.com/ride/2571095/4
Posted May 24, 2008 · 13:59 UTC#22
That does look good man, nice work! I'm going to check that site to see if anyone has done a write-up for the F-150 and do mine 8)
