Map off just a hair
By Whiting1977 · May 17, 2008in Problems/Troubleshooting💬 3 posts👁️ 931 views
Posted May 17, 2008 · 19:58 UTC#1
I know this sounds kinda petty but as I enter an intersection it seems the map is about 10 feet behind. It used to be very accurated but just recently changed. I have done no work on the unit so nothing has changed in the install.
Sorry if this is a well covered topic-I did a topic search on the forum but found nothing and I searched the manual but also to no avail.
Posted May 17, 2008 · 23:56 UTC#2
Probably just a satellite or atmospheric glitz
Posted May 18, 2008 · 04:32 UTC#3
Do you have the VSS wire attached? If so,then you can go into your settings and realign your cursor to be more accurate on the map.
