I installed a D2 and GEX-P10XMT XM receiver this weekend in my wifes 02 Honda Accord V-6. I have two problems currently if anyone can help out it would be much appreciated.
1. The speed sensing wire I hooked up to the red wire on the PCM. The Honda tech said to hook it up to terminal 11 on connector D. I keep getting an error saying that this is not a good connection when I use the test connections button on the unit.
2. I keep getting a check antenna error for the XM. At first it did this when I tried activating the unit. After a while it started working. Then yesterday morning after we came out of the mall and got in the car it said check antenna again. I tried connecting one of my XM antennas from inside my house ot the unit and it still gives this error. Is it the receiver or did I loose my activation?
I did do the bypass and grounded the extra pin on the harness and grounded my parking brake wire. Please help, thanks.
Posted Aug 14, 2006 · 13:33 UTC#1
