Z2 Auto-dimming and daytime brightness issues
By dechief4 · May 19, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,672 views
Posted May 19, 2008 · 15:35 UTC#1
Hey guys.
New Z2 installed (in an '07 GMC Envoy Denali) over the weekend (I did not perform the install myself), and I've got a couple of issues.
1) Auto-dimming for night time. This does not work. I understand the dimming should occur automatically when the headlights come on. The installer showed me two (2) orange ILL wires (one had a white stripe, IIRC). He connected both of these wires separately and together, at my suggestion, to the vehicle's ILL wire (this was coming out of the add-on Onstar wiring harness adapter) and no combo worked to induce nighttime illumination with the headlights on (or off, for that matter). Any ideas?
2) The daytime brightness seems very weak (I have adjusted the dimmer/brightness/contrast settings). It is almost unviewable in anything other than a shadow (and if you're wearing sunglasses - polarized or not - forget seeing the screen). Am I missing something here? I understood this was supposed to be an easily viewed screen in daylight. Maybe there is a protective film I wasn't diligent enough in removing?
TIA advance for your suggestions/help.
Jon
Posted May 20, 2008 · 00:37 UTC#2
I can't give you vehicle specific info, but I can see mine easily in the daylight.
Sounds like your installer may have you hooked up with the unit thinking it's night time (already dimmed). What color is the background when you view your maps? Mine is black at night, so if your is in the daytime, then they've got your wires crossed...
Posted May 20, 2008 · 01:03 UTC#3
Thanks for the reply. My background is a light grey color...
Posted May 21, 2008 · 01:09 UTC#4
No other help or suggestions guys???
Jon
Posted May 21, 2008 · 05:20 UTC#5
Adjusting the dimmer, and only the dimmer should make the screen plenty bright to see. You either have an installation problem or a hardware problem
Posted May 23, 2008 · 08:25 UTC#6
the installer didn't tap into the dimmer wire located on the left side of the steering wheel. that will do the trick.
Posted May 23, 2008 · 11:38 UTC#7
Thanks again for the suggestion, guys! I'll give 'em a try.
Posted Jun 11, 2008 · 03:29 UTC#8
I have the 1st problem as well... it doesn't switch to night mode at all. :x
Posted Jun 13, 2008 · 16:11 UTC#9
Im having the dimming problem with mine as well. I have a Z2 installed in my 03 Lincoln Town Car. Any suggestions 4 me?
Posted Jun 13, 2008 · 16:12 UTC#10
