Is the Nav disc in the unit or removed after install?
Posted May 21, 2008 · 22:04 UTC#1
Depends on the installer. Some use the disk to do a diagnostics check, some don't. And even then, some may leave it in, some may take it back out. It does not come from the factory with the disk in it, if that's what you're asking. If you had it installed, and you can't find the nav disk and it's not in the drive, call the installer.
