Is there anyway to ground the parking break wire without removing all the paneling in my car again to get to the parking break z3 parking break wire?
Please help
Please help
You can do it by disconnecting it from the brake wire and ground it to your vehicle frame.
Well if you can REACH the wire without removing your dash panel then the answer is yes. If not, then no, you'll have to remove the panel.
not to mention if hes grounding it out, not just relocating it, then he probably didnt alter the mute wire either, so yes youll probably hafta take it apart again
