Avic-D3 bypass a success?
By LostAngel · May 24, 2008in Hacks/Mods💬 6 posts👁️ 2,625 views
Posted May 24, 2008 · 14:48 UTC#1
I did the bypass last night...I notice when I start my car and the nav comes up...I get a warning saying the parking brake isn't connected right on the screen...I am able to view maps and press the screen on the map...is this right?
EDIT:
It seems like it isnt working...DVD cuts off at 10mph. I dont see how I did this wrong though...I moved the mute wire from the one location to the one directly above it...connected the parking brake wire on the GMOS-04 harness to the Parking brake wire of the radio...then grounded those two with the MUTE wire....was that right? I thought I followed the directions.
Posted May 24, 2008 · 15:34 UTC#2
You were supposed to move the mute wire up on the harness...Also the parking brake wire should not be connected to the metra harness, it should be going straight to ground.
Reread all the bypass threads.
Posted May 24, 2008 · 15:35 UTC#3
You dont need to connect the parking brake wire to the harness. You should take the Parking Brake Wire(Green) and ground it with your moved Mute Wire(Yellow with Black Stripe), while each is only connected to the D3.
It should Go Like This:
AVIC-D3
l l
l l
l V
l Moved Mute Wire----------
l l
V l
Parking Brake Wire---------V
l
l
V
Ground
Sorry thats the best diagram I can make on a message board. Hope that helps
Posted May 24, 2008 · 15:36 UTC#4
Would that cause the error message on the parking brake not being connected right?
Posted May 24, 2008 · 17:34 UTC#5
YES. Read the bypass topics. Do what they tell you to do. It WILL work.
Posted May 25, 2008 · 00:25 UTC#6
I did encounter a problem with mine, turns out the stupid accessory plug started coming out...It's a tight fit behind my deck so I must've knocked it loose before, took everything apart a min ago and reinserted the plug, then carefully reinserted the deck...So far so good.
