AVH-P4000DVD connected to a 4 ch amp no sound on rear
By bling78 · May 24, 2008in Car Audio💬 6 posts👁️ 5,322 views
Posted May 24, 2008 · 22:53 UTC#1
I just installed the unit today. My front and rear speakers are connected to a 4 channel kenwood amp 1 speaker per channel. I connected the FR, FL, RL, RR RCA's on the back of the pioneer. But I am unable to get any sound on the rear speakers the front works fine. But If i turn on the subwoofer mode the rear channel starts working but it will only play the low frequencies like a sub. How can i get all 4 channels to play with out it thinking 2 of the two rear channels are sub outputs. When i turn off the sub mode it plays no sound at all. I have adjusted the setting fade to rear as far as it can go to test the rear speakers.
The instructions show that the rear can be used as a rear output or a sub output so am I missing a setting here? currently it is set to Sub off. F&R fade is in the middle. L&R blance is in the middle. What else can i change?
Posted May 25, 2008 · 16:20 UTC#2
Hey Bling,
I have the exact same problem. Mine is wired through a Metra harness to retain the factory amp in a 2002 Lexus IS300. Were you able to find a resolution to this? Does anyone here have experience with this same problem?
Thanks.
Posted May 25, 2008 · 17:03 UTC#3
no i have not yet found the solution so if anyone has any thoughts on this that would be greatly appreciated. Thanks in advance.
Posted May 27, 2008 · 03:09 UTC#4
Ok this is how the problem was solved for my situation:
See Pg.39 of your manual
Setting the rear output and
subwoofer controller
This unit’s rear output (rear speaker leads output
and RCA rear output) can be used for fullrange
speaker (FULL) or subwoofer (S.W) connection.
If you switch the rear output setting
to S.W, you can connect a rear speaker lead
directly to a subwoofer without using an auxiliary
amp.
Initially, the unit is set for rear full-range speaker
connection (FULL). When rear output is
connected to full range speakers (when FULL
is selected), you can connect other full range
speakers (REAR) or a subwoofer (S.W) to the
RCA rear output.
! When the multi-channel processor (e.g.,
DEQ-P8000) is connected to this unit, you
cannot operate this function.
1 Touch REAR SP on the initial menu.
2 Touch < or > next to REAR SP to switch
the rear output setting.
Touch < to select full-range speaker and FULL
appears in the display. Touch > to select subwoofer
and S.W appears in the display.
# When no subwoofer is connected to the rear
output, select FULL (full-range speaker).
# When a subwoofer is connected to the rear
output, select S.W (subwoofer).
# When the rear output setting is S.W, you cannot
operate the following procedure.
3 Touch < or > next to PREOUT to switch
the subwoofer output or rear output.
Touching < or > will switch between S.W and
REAR and that status will be displayed.
Basically the setup for the Rear needs to be Full and not as 'S.W.'
Give it a try, it solved my problem. After this, you shouldn't be able to control your 'Bass' except through 'Bass Control'
Posted May 27, 2008 · 04:49 UTC#5
thanks that was exactly the answer I was looking for I did not know there was a initial settings menu. I guess i need to explore the unit interface more.
Posted Oct 12, 2008 · 08:58 UTC#6
Wow this helped me too. I had spent hours trying to figure this out and checking connections, taking out my HU/dash, etc. I thought I checked all menus but apparently never could find the inital menu, now I know I guess. Thanks to google for pointing me to the anser finally.
