Ipod issue and radio issue?
By smbstyle · May 25, 2008in Problems/Troubleshooting💬 14 posts👁️ 1,312 views
Posted May 25, 2008 · 05:26 UTC#1
Hey all, I purchased a vehicle recently already with the AVIC D1 installed, with the Sirius satellite radio tuner. I have the Ipod plug routed to the center console, and whenever I plug the Ipod into that port, the Ipod screen lights up, and after about a few seconds it says "charging", so the Ipod is getting power, but whenever I go to the main audio/source menu where it shows all of the sources, the AUX "button" never becomes raised, and I cannot select it to use the Ipod; only the Sirius and FM buttons are raised, meaning they are the only possible selections for sources.
Also, my second issue is I noticed that I am getting hardly ANY FM radio reception, it is mainly static. Is there anything I can do as far as the AVIC to make sure the connections are right for the FM radio and to get a better signal without static?
Posted May 25, 2008 · 10:48 UTC#2
Are you using the Pioneer ipod adaptor? If so, it would show up as ext-1, not aux
For FM, did your vehicle require an antenna adaptor? Or does it have a powered antenna that should have been hooked up to the deck?
Posted May 25, 2008 · 14:18 UTC#3
yes it does have the pioneer ipod adapter, but I am not sure about the FM antenna, i will find out.
anyone have any idea about the ipod issue?
Posted May 25, 2008 · 19:42 UTC#4
So is EXT1 lit up in the source menu?
Posted May 25, 2008 · 21:09 UTC#5
Nope, nothing lights up at all when the Ipod is plugged in.
Posted May 25, 2008 · 21:15 UTC#6
Take a look at the ipod adaptor and see what model it is
Posted May 26, 2008 · 02:06 UTC#7
do you mean the cable itself or the box the cable plugs into?
Posted May 26, 2008 · 09:20 UTC#8
What connects the head unit to the ipod? It should have a model # on it
Posted May 26, 2008 · 12:32 UTC#9
it connects to the sirius tuner which then connects to the head unit. that model number is SIR-PNR1
Posted May 26, 2008 · 22:12 UTC#10
Thats the sirius model number. Whats the ipod part?
Posted May 27, 2008 · 01:06 UTC#11
Ill see if I can find out, I bought the car from someone with it already installed. In the mean time, would you have any idea what could be the problem?
Posted May 27, 2008 · 01:29 UTC#12
Ya, could be the wrong brand ipod adaptor
Posted May 27, 2008 · 01:45 UTC#13
so are you talking about the adaptor that connects from the ipod to the sirius tuner, or from the sirius tuner to the AVIC unit?
Posted May 27, 2008 · 02:00 UTC#14
Ipod. The thing that plugs into your ipod. Whats the model number on it?
