GPS antenna is getting really good signal like this so this is where it will stay!
tjdehya said:Nice job, looks clean. Was this you first install? It’s good to see people doing their homework and saving themselves some money. Looks great. 3hrs is much better than what it took me... but I didn’t know about all the good stuff I can learn from AVIC411 until after the install :( . Enjoy your Z1 :D
hiddenfromtherest said:Just so you know, the GPS antenna can go underneath your plastic dash. I have the same truck and just stuck the magnetic antenna to one of the steel support underneath the plastic dash and have not had a problem with signal.
hiddenfromtherest said:How exactly did you hook up your dimmer wire, mine didn't work directly off of the adapter so I installed a switch under the dash for now. I just purchased the "ducati" circuit so any info to make it work with the headlights would be appreciated.
hiddenfromtherest said:Otherwise just run the wire above your headliner and run your wire through the edge between the metal and plastic on the the top of the third brake light.
crease-guard said:I have a 2001 HD I'm about ready to install my Z1 into (was originally going to install in my Z06 but plans changed....I'm going car computer in that one).
My trucks opening is a 1.5 DIN so I've got a radio bracket and dash bezel coming in next week. I don't think I have the bose in my truck (don't think it was offered in the first year of these trucks) so I'll just use the AVIC's onboard amp for right now. Eventually I might go with a 5 channel surrond setup but for now we'll use the stock speakers.
Jay
ufd108 said:Or you could remove the factory XM and place the Pioneer one right there. Then you only need a 2-1 connector adapter, which I believe is fairly cheap (trying calling XM and they might send you one for free to keep your service).
fastbagz said:looks good. i have too been told that it wouldnt work in my 02 suburban but it looks like your dash is about the same. crutchfield site said it wouldnt work so i'm not sure. and i havent found anything on this site to verify it. anyone know what the deal is? i have Onstar (dont use it) and a good factory system but i dont think its a bose.
thx!
ralphhood3 said:The XM antenna won't work under the dash.
