2006 Civic VSS wire clueless
By bob67 · May 26, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,953 views
Posted May 26, 2008 · 04:13 UTC#1
Hooking up a z2- I've found the VSS wire. Now what do I do? I have connected the connector below an adapter that connects to the z2 unit. Does this mean I already have the vss hooked up?
Also, I've seen someone with a z2 that has a day and night function. In daytime the map has a white background, at night, the map has a black background when headlights turn on. How do you do this?
image linked from:
http://www.8thcivic.com/forums/mechanic ... e-vss.html
Posted May 26, 2008 · 04:54 UTC#2
You'll need to tap into that wire with the vss wire off your head unit.
Posted May 26, 2008 · 06:20 UTC#3
Yeah, tap your VSS from your computer to the headunit with the pink wire that came with your Z.
You can setup the day/night functions using the illumination (ILL) wire.
Posted May 30, 2008 · 04:36 UTC#4
I have an 07 civic si and i just got a z3 installed and it doesn't auto-dim when i turn on the lights. Putting the fact that they could have not connected the orange ill wire, is it possible that its something else??
Posted Jun 27, 2008 · 19:58 UTC#5
If the night time background does not come up with the lights turned on then most likely it is your illumination connection. It maybe a hardware issue.
Posted Jun 30, 2008 · 04:14 UTC#6
It was the ill wire, i fixed it myself thanks.
Posted Jul 10, 2008 · 03:51 UTC#7
I have an 07 Si too. :wink:
Any probs w/ the z3?
