ptr7
By jdrl · May 26, 2008in Hacks/Mods💬 8 posts👁️ 2,392 views
Posted May 26, 2008 · 05:36 UTC#1
Anyone using this (ptr7) with there n3?
If so how did you wire it?
Thnaks
for any info
jdrl
Posted May 26, 2008 · 09:23 UTC#2
just flip the switch and ground the parking brake wire
Posted May 26, 2008 · 17:19 UTC#3
no.
Posted May 26, 2008 · 17:21 UTC#4
Thats the stock responce.lol.
NO I would like to know how to wire the ptr7,
again
thanks for any help
jdrl
Posted May 26, 2008 · 22:14 UTC#5
It won't work without flipping the switch anyway
Posted May 26, 2008 · 23:17 UTC#6
If you must know- here ya go. put PTR7 into program mode. power it up with red and black wires (any 12 volt source will do) and ground the brown wire twice. when the led flashes rapidly then quits, remove power. flip the switch back on the PTR7. connect the red to the red of the pioneer harness. black to ground. green to the remote turn on. white to the parking brake. toggle the switch under the head unit. happy viewing!
Posted May 27, 2008 · 01:03 UTC#7
Why not just flip the bypass switch under the foil sticker and ground the green brake lead like was mentioned already? two step process.
Posted May 27, 2008 · 03:55 UTC#8
Thanks for the info,
its set from the factory that way. What i would like to know is why did mine come with a toggle switch as well (the ptr7)?
I had no clue about the switch under the foil untill I tryed to fine help getting the ptr7 wired, Then I found this site, now I dont mind just flipping the switch but I would like to use the ptr7 the way it is ment to work, only because I paid for the stupid thing.
thanks for any help.
jdrl
