Can anyone tell me where to find the reverse wire in the driver or pssenger seating area? I would prefer to not have to drill thru the fire wall and run the wire to the reverse lights.
Thanks in advance.
Thanks in advance.
Here's where it is on the 06. Not sure if the 07 is the same or not so I'd test it to make sure prior to hooking it up to your system.
Reverse Light light green BCM, black plug, pin F
The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
