D3 bypass without interfering with mute capability...
By Sedg · May 27, 2008in Hacks/Mods💬 13 posts👁️ 2,819 views
Posted May 27, 2008 · 05:42 UTC#1
I wish to preform the D3 bypass without interfering with mute capability.
I have a 2007 Trailblazer SS with Onstar integrated and need/want my mute function intact.
I think I must be missing something in the write ups because I don't understand why you couldn't just add an additional wire to the harness to facilitate the bypass.
Big brains please speak up and guide me in the right direction.
Cheers,
Steve
Posted May 27, 2008 · 05:59 UTC#2
From what I read in one of the posts here.. If you wanted, you could pull a wire that you were not going to use and just move it.. I could be wrong or may have misread it, but I'm pretty sure it was said that you could use any of the pins in that harness..
GL!
eGo
Posted May 27, 2008 · 06:38 UTC#3
You don't NEED to use the mute wire. You can use ANY wire on that harness, it's just suggested to use the mute wire because it's almost never used.
Posted May 27, 2008 · 15:33 UTC#4
I'm not 100% certain but if my harness is utilizing all of the wires (VSS, brake, mute, etc.) why couldn't you just install another wire to the empty location of the harness to work the bypass?
Posted May 27, 2008 · 15:58 UTC#5
Because you need to have the proper pin to fit in the wiring harness. You can't just shove a wire in there and hope for it to stay in. The pin clips in the harness and will not come out. Doing it any other way is just asking for connection problems.
Posted May 27, 2008 · 17:50 UTC#6
I guess I really need to spell this out to avoid the miscommunication.
I understand you couldn't just stuff a wire in there and make it work, well at least not reliably for any length of time. :roll:
ASSUMING a person utilizes an appropriate pin to retain a newly installed wire into the appropriate location within the harness connector, this method should also allow the bypass to work correctly.
... unless I'm missing something else?
Posted May 27, 2008 · 17:58 UTC#7
Yes, that's absolutely true. The problem is finding the proper pin/clip to fit in the harness, which is why it's usually suggested to use one of the existing wires. But if you can find the right type of connector, you can use any wire you want, as long as it grounds the circuit at that pin position.
Posted May 27, 2008 · 18:06 UTC#8
Perfect!
Thanks for the clarification.
8)
Posted May 27, 2008 · 22:53 UTC#9
My 07 Silverado has onstar and the mute wire was NOT being utilized by the Scorsche harness...Bypassed and Onstar still mutes the radio when activated.
Posted May 28, 2008 · 03:14 UTC#10
i may have posted this before but, i have installed at least a dozen avic d's in the past few years, on the d3's, if you do not want to move that wire you can get a DEI antenna wire from an alarm or remote start system with the antenna harness and cut it open from the black plug side closeset to the antenna and take any of the three wires out with the pin, the pin in that harness fits EXACTLY in to that open slot for the bypass.
Posted Jun 02, 2008 · 23:30 UTC#11
Awesome! I'm sure I have an old DEI unit in a box somewhere.
Packrat joy!
Posted Jun 03, 2008 · 02:17 UTC#12
You do not need the mute wire for onstar. The only time you do use the mute wire, is on a aftermarket hands free kit which has a seperate speaker.
The correct module for your car will take care of muting internally, or it will just shut off the radio.
Posted Jun 03, 2008 · 11:23 UTC#13
If you hook the mute wire of a radio to the interface it won't turn off the radio it'll mute it.
