2006 Trailblazer and the AVIC-Z1
By jwsievers · Aug 15, 2006in General💬 7 posts👁️ 1,323 views
Posted Aug 15, 2006 · 22:05 UTC#1
I have a 2006 Trailblazer LT and I am curious if the AVIC-Z1 will fit in it. Also does the navigation require nav disks or is it all stored on the harddrive?
Posted Aug 16, 2006 · 13:44 UTC#2
no nav discs required, Nav runs via the HDD.
As to the trail blazer fit, I don't know that answer, but I bet you can find that out on the crutchfield web site.
Posted Aug 16, 2006 · 15:12 UTC#3
yes it will fit. i have one in mine.
Keith
Posted Aug 16, 2006 · 23:12 UTC#4
do you have any pictures? Also any suggestions when installing to the trailblazer? What fitment kit did you use?
Posted Aug 17, 2006 · 02:51 UTC#5
To make the z1 fit in an 05 You have to cut out some plastic support for the back of the stock radio. As for the kit you can get a metra 99-3301 and just use the side brackets. I've done this several times in Trailblazers up to 05. From what I've seen of the 06 I don't see it bing much different.
Posted Aug 17, 2006 · 17:50 UTC#6
or a metra 99-2003
Keith
Posted Aug 18, 2006 · 00:51 UTC#7
I've tried the 2003 kit, it never worked properly for me, but then again that was in older trailblazers. Maybe the new one is different.
