Can't get the firmware update disc to work.
By sgtbilko · May 28, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,536 views
Posted May 28, 2008 · 22:20 UTC#1
I have a brand new z-2 and I'm trying to do the fimware upat. I am writing the files to a CD-R using Roxio at 8x recording speed. Roxio is programmed at Mode-1 and Disc-at-once.
I insert the disc in the unit and the unit says "CD Inserted". After five minutes, nothing happens. Anybody know what I'm dong wrong?
Posted May 29, 2008 · 03:09 UTC#2
It should be one DAT file and one folder that you are burning. Is that correct?
Posted May 29, 2008 · 22:28 UTC#3
I've done everything by the book. I've left it in there for a half hour, but it just says "CD-ROM Inserted".
I'm considering calling Pioneer and having them send me a free copy.
Posted May 29, 2008 · 22:37 UTC#4
Once it says "CD Inserted", did you try holding in the Map button? I've heard of some people having luck with that.
Posted May 29, 2008 · 23:48 UTC#5
Did the whole "hold the map button down" to no avail. Anyone else use the Roxio program? What settings did you use?
Posted Jun 08, 2008 · 00:26 UTC#6
I'm having trouble with this update as well. I inserted the disc and the update worked, BUT it froze at about 80% and automatically restarted. Everytime I start the car, it says it's restarting the update and then is says update failed. This message goes on and on and never stops.
Does anyone know what I can do?
Posted Jun 13, 2008 · 06:26 UTC#7
I am having the same problem. Please help, right now I have a very expensive paper weight.
Posted Jun 14, 2008 · 02:56 UTC#8
Try using a different burning program...I think I tried 3 before I found one that worked for me, and Roxio was one of the first two.
