D3 Installation Problems - 2008 Charger
By BladeWrythe · May 29, 2008in Problems/Troubleshooting💬 4 posts👁️ 778 views
Posted May 29, 2008 · 01:17 UTC#1
Ok gurus...
Having some trouble w/ my installation and I wanna see if there is anything else I can possibly do before I go thru the hassle of pulling everything back out and exchanging my shiny new D3 for a replacement D3.
So here goes...
I have a brand new 2008 Dodge Charger R/T w/ the 6 speaker Boston Acoustics system in it. I purchased a AVIC-D3 w/ the BlueTooth kit. After installation, the sound it flickering off and right back on approximately every 8 to 10 seconds.
I originally installed the unit via a Metra CHTO-03 wiring harness. After 2.5 hours of phone support w/ Metra, they advised me to exchange the harness. Unfortunately, all local shops were out of the Metra harness, so I ordered and recieved the PAC C2A-CHY3 harness. After installation w/ the PAC harness, the unit is doing the exact same thing. I have checked and re-checked all the wire connections. I have also done the 15m battery disconnect. All to no avail.
So, am I missing something retardedly simple, or do I really have a defective AVIC-D3 like all my friends are telling me? Thanks in advance for your help.
-Mike
Posted May 29, 2008 · 02:44 UTC#2
I can't be of much help as my Maggie only had the 4 speaker system w/no amp.. But if it's not the D3 the only thing I can think of is that the CAN BUS system is going goofy, but sounds like it may be the D3 More than the CAN..
Posted May 29, 2008 · 03:10 UTC#3
try getting the usb updater cable and use the metra chto-013 this is the only harness i have gotten to work properly. you have to get the harness and update it then install it. any questions i recommend talking to andy in metra's tech support he is awesome and has always come through.
Posted May 31, 2008 · 06:29 UTC#4
Or dump the Metra piece and try a Peripheral CHYAH06. You will lose fade capability, but it works.
