Can't dial number in phonebook
By luvrbcs · May 29, 2008in Problems/Troubleshooting💬 1 posts👁️ 552 views
Posted May 29, 2008 · 12:34 UTC#1
Let me preface this with earlier the BT was working perfect. Phonebook transferred over, presets set, everything worked fine. Also searched, found nothing similar.
Had problems last week with no sound on the BT but got that resolved by resetting the D3. At least I think it was resolved?
After resetting the D3 I had to pair and register the phone over again. No problem.
Transferred two numbers over from the phone, no problem.
Went to the Phonebook on the D3 to add the numbers to the preset. Problem.
When I select the number/name, all it does is highlight. The only options I see are the buttons in the bottom right corner; Back and Esc. If I hit Back, it shows the Phonebook again; Esc takes me out.
I thought that when I select a number/name from the Phonebook I was to get other options, like dial, etc. I don't. I can't call anyone unless I direct dial. WTF.
Think the BT module is shot? Or is this a function of the D3?
