Avic z2 bypass upgrade
By teonaltima · May 30, 2008in Hacks/Mods💬 5 posts👁️ 2,167 views
Posted May 30, 2008 · 19:10 UTC#1
When I put the CD in for the bypass, it says I'm trying to install the old software and I've never attempted to load software on the deck. I burned a copy of the software recommended and that was the results that I got. Is there a new version out or something? I would think if I'm up to par then I should be bypassing the functions that I'm trying to bypass. Have I missed out on something? What should I do. I've searched and searched and searched!
any help provided will be greatly appreciated
-Teonaltima
Posted May 30, 2008 · 19:36 UTC#2
Nothing new... if it says you're up to date just do 2-wire and good to go.
Posted Jun 06, 2008 · 23:24 UTC#3
-Teonaltima
I had the same problem dude, and it is still giving me issues. Even 2 local professional install shops that do these bypasses have been unable to do both the bypass for me as well as the firmware, due to the problem you described. They encounter the same issue as I do, everything has been double checked...wiring etc. And the firmware version indicates the version BEFORE the firmware upgrade. I dunno man. I gave up on trying to get either one of them to work. I spent money to try and get this done and nothing got resolved in the way of a firmware update or a bypass. The instructions may be simple and straight forward on here, yes, and I have even had people who get paid to do this type of thing for a living look at my Z2, so I know it is not just me. Something is up with my Z2. All I can say is be prepared to be frustrated.
Posted Jun 07, 2008 · 01:23 UTC#4
Have you tried to use the z3 image on your HD to see if the firmware upgrade would work directly from the HD?
Posted Jun 19, 2008 · 19:35 UTC#5
Yeah crazy stuff here...load the upgrade disc..go to maps,and it tells me that the software is already in there...press the reset...and nothing,the E-brake still has to be on for video to work!!! HELP
