Voice command with Ducatiboy flasher
By macalanche · Aug 16, 2006in Problems/Troubleshooting💬 1 posts👁️ 838 views
Posted Aug 16, 2006 · 12:40 UTC#1
So I was playing with the voice command (VC) yesterday and came across some odd issues (not really problems). I have the Ducatiboy flasher circuit installed so I’m able to access everything. If after starting I go straight to a voice command, I only get a couple options and the “This command is unavailable” response. If I hit the Menu button first, see everything is available and then hit the voice button, I have complete control. I also noticed that if I don’t use the VC for a while it won’t give me all the options while in the AV screen but I do get all options while viewing the Map.
The only real problem I ran into was when using VC to call from my address book; it would lock up every 3rd or 4th try. The only fix seemed to be shutting down completely and re-booting.
