Sirius connections
By GTI Chooch · Jun 05, 2008in Pre-Release Archive💬 10 posts👁️ 3,095 views
Posted Jun 05, 2008 · 14:11 UTC#1
I am ordering the 900BT and I want to have Sirius. I know I am going to need to order the CD-SB10, and the SIRIUS SC-C1.
My car (2008 VW GTI) currently has Sirius through the factory head unit. My question is, can I use the existing Sat Radio antenna? If so what additional items do I need to buy to get this to work? Or will the existing antenna plug into the SIRIUS SC-C1?
Posted Jun 06, 2008 · 03:48 UTC#2
x2 ... i have an '08 VW GLI with Sirius and also would like to know what (if any) additional equipment i need if i already have a Sirius antenna/tuner installed.
Posted Jun 06, 2008 · 06:25 UTC#3
Take a picture of what the connector looks like on your factory antenna and report back
Posted Jun 06, 2008 · 14:31 UTC#4
Here's pic....
Keep in mind our factory antennas handle both terrestrial radio and Sat radio...not sure if this is going to screw anything up
Posted Jun 07, 2008 · 02:45 UTC#5
I have a 2007 GTI and I was not able to use my Sirius antenna on my D3, I had to install a dedicated one... bummer.
Daniel
Posted Jun 10, 2008 · 04:37 UTC#6
my question is, i have the sat radio unit for the AVIC D3 will I be able to use that one or will i have to get another?
Posted Jun 10, 2008 · 05:43 UTC#7
Same one will work with the Fs
Posted Jun 15, 2008 · 20:22 UTC#8
Daniel
Wow the misconceptions on this board are amazing.
I have a 2008 R32, factory Nav. My installer used the factory Sirus antenna no problem! Works BETTER than the factory setup.
Who is doing these for you guys?
Posted Jun 15, 2008 · 21:36 UTC#9
I have the D3 and am considering the F series as an upgrade. My main concern is with Sirius. Do yo have to use the CD-SB10, and the SIRIUS SC-C1? Or can you use the SIR-PNR2 with the F series unit?
I am mostly concerned with the Sirius display on the unit. I would be in haven if it has a 2 line display. Please post any observations in this regard. Thank you.
Posted Jun 16, 2008 · 03:34 UTC#10
You can use either of the setups you mentioned. They both have the same display functionality (one line)
