HDTV tuner for the F series
By madsonp · Jun 05, 2008in Pre-Release Archive💬 4 posts👁️ 1,391 views
Posted Jun 05, 2008 · 23:26 UTC#1
Do you guys think this would work with the USB connection of the new F-series to recieve the HDTV signal ????? I realize the resolution would'nt be in HD on the head unit, but I wonder if this could be a way of recieveing a TV signal once analog goes away ?
http://cgi.ebay.com/Digital-USB-2-0-DVB ... dZViewItem
Posted Jun 06, 2008 · 13:30 UTC#2
No, every USB tuner has its own set of drivers, and the F-series doesn't have drivers for that USB tuner. I would say it's safe to say the F-series doesn't have drivers for ANY USB tuners and the F700BT won't even have a built-in MPEG2 decoder which would be required because ATSC broadcasts are in MPEG2.
You would have to reverse engineer and hack the OS to make it work. Seeing as how the F-series supports MSN Direct, I'm guessing these run Windows Automotive 5.0, but who knows?
Posted Jun 06, 2008 · 22:20 UTC#3
Well, I kind of figured as much. Just wishful thinking I guess. Thanks.
Posted Jun 07, 2008 · 04:23 UTC#4
Friend of mine just hooked up a digital tv tuner box (sd) and has it hooked the av input on his Z2 to receive digital television.
With the voucher for the box his total for the project was like 9 bux.
