popping noise from speaker
By bertom2000 · Aug 16, 2006in Problems/Troubleshooting💬 5 posts👁️ 2,363 views
Posted Aug 16, 2006 · 15:42 UTC#1
i have a 2003 Kia Optima SE with factory infinity sound system. i installed a avic d1. when i shutoff my car i get this popping noise that comes from my speaker. What could be the problem?
Posted Aug 17, 2006 · 02:57 UTC#2
It's a turn off pop coming because you car has a factory amplifier. You can try putting a 300-500 ohm resistor on the remote wire. You best bet would probably be to remove the amp in it's entirety.
Posted Aug 17, 2006 · 13:23 UTC#3
looking up your wiring it depends on who installed your radio. i have installed many radio in that vehicle and never had a problem. plus you dont want to remove that amp with the factory speakers still in place. the factory infinity speakers are at a 2 ohm load to low for the avic. the recomended ohm load on the avic is 4 -8 ohms. you would have to put in a 4 channel amp or remove the amp and replace all the speakers. plus removing the output of your speaker will be lower at any volume. if you can remove the radio. i can go over the install to insure that it is installed properly. so it took awhile to respond.
Posted Aug 18, 2006 · 16:21 UTC#4
will this popping noise cause damage to my speakers? this noise comes from my left front speaker
Posted Nov 06, 2006 · 22:27 UTC#5
I have a '06 Hyundai Azera with premium Infiniti sound system; just installed the Z1, and have the same loud popping noise when I turn off ignition; I used the speaker wires from the Z1's power harness (as opposed to the RCA connectors on the RCA harness); is this correct? It sounds OK (except for the popping, and a constant lo-volume hiss that's present no matter what I'm playing, including nothing at all!)
