How easy is to pull out a D2 and install a D3 or AVIC-F900BT
By cooldw57 · Jun 06, 2008in General💬 3 posts👁️ 786 views
Posted Jun 06, 2008 · 16:50 UTC#1
I currently have a AVIC-D2 with Pioneer GEX-P10XMT XM NAVTraffic and MP3 module installed. I'm thinking about selling the AVIC-D2 for cheap and just buy a cheap D3 or F900BT off ebay. Would it be just a plug and play with the existing wiring hook-ups? I'm hoping most wiring are the same so all I need to do is to take out the D2 HU, disconnect the wires on the back and reconnect to the head unit of D3 or F900BT without re-wire the VSS, XM, MP3 and GPS antenna etc.
Your help is greatly appreciated!
Posted Jun 06, 2008 · 17:34 UTC#2
They use different wiring harnesses, so you would have to re-wire everything. The good part is you've already got the VSS, parking brake, reverse signal, etc. run up into the dash, so that's a little less work there.
Posted Jun 06, 2008 · 19:24 UTC#3
Different antenna too. Still shouldn't be too difficult to swap in the new harness and run a new antenna
