I spent a few hours tonight poking at different options to bypass the detailed nav functions lockout while moving.
After probing around there are no definitive signals coming in that indicate park so grounding such a wire is not an option.
Disconnecting the speed input does cause a nag message to pop up at power on about a system modification may have been performed and to see your dealer.
In order for the "bypass" to work the GPS antenna and speed input (pin 16 on the middle plug) must be disconnected. Of course there will be no map movement while it is in bypass so it would have to be a toggle switch or the like.
Anyone know where I could get a short cable that the nav system uses so I could build a box with some relays to open the antenna signal (or short it to ground) to disable the input? Also is this maybe something that can be done via software? I saw no obvious solder bridge config jumpers a'la D3 when I took the top off.
Anyone been down this road before?
