Dimmer problem with N4 & solution
By heavymetals · Jun 09, 2008in Problems/Troubleshooting💬 2 posts👁️ 1,639 views
Posted Jun 09, 2008 · 23:55 UTC#1
The dimmer function is controlled by pulse width modulation in my C5 Corvette and just happens to be inverted logic of what the N4 needs to see.
I used a npn transistor and three resistors to fix that.
Now the screen "reverses" or goes to a black background on the lowest dimmmer setting like it is supposed to.
This is not really covered in the documentation very well if at all.
I couldn't find any info so I just hung a scope on the dimmer lead and took a peek.
Here is a link on building one. Ignore the 5v and use 12v.
http://www.play-hookey.com/digital/expe ... erter.html
I used a third resistor (100k) as a pull down on the input.
Posted Sep 18, 2008 · 05:11 UTC#2
bump
