How hard will the reinstall be? Do I need to purchase any new connectors?
Posted Jun 10, 2008 · 00:30 UTC#1
You shouldn't need to purchase anything new. The wiring harness adapter and mounting kit will work for either unit. You just have to do some rewiring. If you installed the D3 yourself, removing it and installing the F will not be a problem.
The harnesses are said not to be the same between the D3 and 90BT. I cant confirm this yet but i should be recieving my 900BT next week sometime. Although the general wire colors are the same, just different locations in the new harness. Called Sonicelectronix and they should be gettint their stock this friday then my unit will ship.
Harness, GPS antenna, and RCA plug are different
