AVH-P4000 Question
By blee · Jun 12, 2008in General💬 8 posts👁️ 2,904 views
Posted Jun 12, 2008 · 00:52 UTC#1
I have a couple of different external HDs that I have tried getting to work on the new HU. Nothing seems to work right other than a USB thumb drive. Can anyone tell me what external USB HD they are using with success?
I have tried a 60gb WD and a 120GB WD. I reformatted both to FAT 32 just to make 100% sure that they were formated correctly, place just one folder on the drive and the Pioneer either reads NA USB Support or it will pull up as if it was reading the drive as read format then shut off the unit to the menu select screen. Again this works just fine on a USB thumb drive with the same file folder.
Any help would be great before I send it back for replacement.
Posted Jun 13, 2008 · 14:13 UTC#2
WOW 40 views and not one person to reply. :o
I guess the ultimate question here is: Can anyone that is using any of the pioneer decks (preferably AVH-P4000) that accepts USB hard drive plug in tell me what hard drive they are using? I am just looking to see if my deck is bad and needs replaced or if there are known problems. From that point I will go to Pioneer tech services and see if they can give recommendations, I have a whole year to get the deck replaced, but unsure if they would send a new unit or refurb, and considering the deck is only 1 week old I would rather get the troubleshooting done before I go through the trouble of pulling the deck out and waiting for the replacement only to find that I need to use another HD or do something else to get it to work.
Can anyone help? Thanks for any help that can be offered.
Posted Jun 13, 2008 · 16:00 UTC#3
i have a sandisk 8gb flash drive, works great. there may not be enough power for the bus powered hdd based usb drives. sometime those are picky on a pc.
Posted Jun 20, 2008 · 00:52 UTC#4
Anyone try using a mobile powered USB Hub. Just wonder if this is a power issue maybe giving it a bit more juice would make the difference.
Posted Jun 22, 2008 · 02:31 UTC#5
i just got a 4000 also. its not playing my Divx files. had any luck with this?
oh by the way, i use a 4GB flash drive and it works fine
Posted Jul 01, 2008 · 18:48 UTC#6
Any update on this? I am looking to get more out of the unit and want to use my Ipod for music videos and an external drive for MP3s...would be nice to get a large HD as opposed to an expensive flash drive with only 32gb.
Ipod is only 30gb...bought a few weeks before they sold the 80gb for same price as 30gb :evil:
Posted Jul 19, 2008 · 18:40 UTC#7
the last 4000 i did i hooked up the hard drive to was a western digital, almost 100% sure of it. They are suspose to handle up to 250 gb drive pulling less that .5 volt. I one i did worked fine. I haven't heard anything fron the customer and that was about 3 month ago or longer.
Posted Jul 31, 2008 · 05:55 UTC#8
I got a 160GB 2.5 mobile hard drive, usb power less than 500mA.. works perfect!
