Reverse Wire
By sportsfan21 · Aug 17, 2006in General💬 21 posts👁️ 4,753 views
Posted Aug 17, 2006 · 20:59 UTC#1
When I opened my dash today to temporarily hook up a DVD player, I found that my installer failed to hook up my Reverse Gear Sensor wire.
If I am not attaching a rear view camera, does it really matter if this wire isn't hooked up?
Posted Aug 17, 2006 · 21:09 UTC#2
In short, no.
-Litos
Posted Aug 17, 2006 · 23:30 UTC#3
When you don't have it hooked up, the navi assumes you're moving forward when in fact you're moving in reverse. As the avic constantly learns and corrects discrepeancies in your car between it's speed, gyro and incline/decline sensors and the actual position, as determined by GPS readings, the accuracy deminishes slightly depending on just how much you move in reverse. If you move 40' in reverse and turn at the same time while the speed sensor tells the Avic you've moved 40' forward while turning you've effectly introduced an 80' error which is multiplied by the turning info. Typically you'll see yourself driving where there is no streets until everything settles down again. With a strong signal from at least 3 satellites that may only take a couple of minutes. Less satellites and a weaker signal will extend that period accordingly.
Posted Aug 18, 2006 · 00:04 UTC#4
So I guess I should have the installer connect that wire.
Actually, if someone could tell me where I need to connect that wire I can just do that myself.
So, does anyone know where I need to connect the reverse signal wire in 2000 Nissan Pathfhinder LE?
Posted Aug 18, 2006 · 01:00 UTC#5
Here ya go.
Reverse Lights YELLOW (+) 20 PIN CONN PASS KICK PANEL
Posted Aug 19, 2006 · 01:55 UTC#6
cntrylvr79 said:
Here ya go.
I'm not 100% sure what that means. Is it that the wire I need is a yellow wire in the 20 pin connected underneath the passenger kick panel?
Please correct me if I'm wrong.
**Edit** I took out the picture because it stretched the page and didn't help.
Posted Aug 19, 2006 · 04:12 UTC#7
The flash from the camera makes it hard for me to see the wire colors. But yeah just count the number of spots in the harness be there a wire in it or not. the harness you're looking for will have 20 pins total. Then look for a yellow wire in that harness.
Posted Aug 19, 2006 · 21:46 UTC#8
Ok, well heres one for you guys.
I pulled back a little of the insulation on the yellow wire in the 20 pin connector and took my meter connected one side on the wire, the other on ground, switched into reverse... and... nothing happened. No change, still 0 reading on the meter.
I double checked this 50 times, checked my meter, checked everything. I even called Crutchfield to see what they said, and they also said I was doing everything right.
So I took apart my taillight and in the wires going to the reverse light there is a yellow wire that looks exactly like the yellow in the 20 pin connector, and all the other wires in the light resemble wires in the connector up front.
So I did a continuity test and it seems that the wire in the back and the wire up front, although they look identical, they are not the same. I tested the wire in the back and when I switched to reverse, I got a reading of 12 volts.
So now, I know I can run a wire from the taillight up to my D2, but do you guys have any clue why this isn't working?
I would appreciate any and all answers because this is confusing the hell out of me. :twisted:
Thanks.
Posted Aug 20, 2006 · 04:51 UTC#9
Odds are then there's another yellow wire in the kick panel. If you've already found it at the tail light might as well just run that up to the front since you now whre it is and the couple minutes it'll take to run that to the front of the truck will be a lot less than trying to find it in the pass kick.
Posted Aug 20, 2006 · 16:18 UTC#10
Yea you were right. As I was about to start running a wire from the tail light, I checked under the kick panel one last time and I noticed in the top connector (I think its 22 pins), there is a yellow wire with grey spots, and thats the wire to tap into. Its wierd because it is exactly the same as the wire that you told me to tap into, but this one is the one you need.
Thanks for all your help guys!
Posted Sep 14, 2006 · 02:20 UTC#11
i have a scion tc were whould i hook this wire up to in my car. should i just run the wire all the way to the back of the car and hook it up to the positve lead on the reverse lamp its self. please help
Posted Sep 14, 2006 · 22:22 UTC#12
Reverse Light pink + top of fuse box, 14 pin plug, pin 2
Posted Sep 15, 2006 · 16:03 UTC#13
where do you find this info?
I am installing an avic-d2 in my 2003 superduty. I would very much appreciate a location for the reverse wire and the Car speed signal input wire(pink). or do I need to purchase a ND-PG1? or is the car speed signal input needed? eh. sorry for the noob questions
thanks
Posted Sep 16, 2006 · 01:07 UTC#14
No you don't need the nd-pg1. Here's where to get your wiring
Reverse Light black/pink + fuse box
The vss you can get behind the radio. In the radio harness there should be a gray/black wire. That's your vss.
As for where I get the info. I have access to a website with the info through work.
Posted Sep 16, 2006 · 02:37 UTC#15
ok cntrylvr79 how about this one? VSS and reverse wire for 1992 Chevy Silverado ext cab pu with 350 and 4sp auto. :?
Posted Sep 16, 2006 · 03:11 UTC#16
Try this for vss.
Drivers kick panel Convenience Center, Spade (ORM)
Nothing I have access to is giving me a color for the reverse. What you can do is pull out the tail light. FInd the wire for reverse there, then look for the same color wire in the drivers kick panel in the harness running towards the back of the truck.
Posted Sep 16, 2006 · 04:23 UTC#17
Translated to laymns trems would be? :shock:
Posted Sep 16, 2006 · 04:57 UTC#18
I'm guessing it's either at the fuse panel or near the fuse panel in the driver's underdash area.
Posted Oct 02, 2006 · 20:46 UTC#19
in the factory radio harness there is no gray wire with a black stripe. any other ideas?
2003 ford f250 superduty
thanks
mike
Posted Oct 03, 2006 · 00:56 UTC#20
Speed Sense gray/black instrument cluster or
Notes: Also found at the radio on vehicles that have the in-dash CD changer.
Posted Sep 25, 2007 · 21:49 UTC#21
I have a 2006 F-250 Desiel with an AVIC-D3 installed already. I recently purchased a back up camera to install. The truck used to have the in-dash CD player before the AVIC install. Can you tell me where and what color the reverse wire is?
How would I confirm it with my multi-meter? Will there be a change in DC current when in reverse?
Thanks in advance.
