Help me figure out these issues please, PLEASE
By supernet · Jun 14, 2008in Pre-Release Archive💬 9 posts👁️ 1,842 views
Posted Jun 14, 2008 · 05:17 UTC#1
I just got the F90BT Installed 2 things are REALLY bugging me
1) On the Maps it is showing downward and not upword , I hit the Red/White arrow and it does nothing ( i really really really would like this to work )
2) For my steering wheel controls everything works but up and down for presets , they tried to program the device to do presets but the F90 won't do it, it worked on the D3
3) The presets won't show for the HD radio(model # GEX-P10HD), just a blank screen with numbers but won't show the presets, is this normal?
Also the installer used the same harness as my D3 but moved like 3-4 wires, is that ok???
I love the radio but would like these 3 issues fixed, PLEASE HELP..
Posted Jun 14, 2008 · 15:32 UTC#2
Anyone?
Posted Jun 14, 2008 · 17:55 UTC#3
I will pay someone to help me!
Posted Jun 14, 2008 · 18:01 UTC#4
Supernet,
Sorry. I can't help you, but I will back you up on the 2-D map issue. I can't figure out how to get the 2-D map to show anything other than North Up. I prefer to have my current heading at the top of the display -- just like in the 3-D image.
I suppose one solution is to select the 3-D map and then use the rotate keys to rotate the image to near vertical. You'd basically get a 2-D display with your current direction at the top.
That may actually be the engineers / designers plan...?
Posted Jun 14, 2008 · 21:55 UTC#5
When JasonH was reviewing the AVIC-F90 on this forum, he stated that the compus will only point North in 2D mode and he couldn't get it to change either.
Posted Jun 15, 2008 · 05:19 UTC#6
Thanks, so what about the harness?
is it really the same as the d3?
Posted Jun 15, 2008 · 05:36 UTC#7
No, they have different harnesses.
Posted Jun 15, 2008 · 20:54 UTC#8
then how is mine working?
So i can yell at the installer
Posted Jun 15, 2008 · 21:28 UTC#9
u should yell at him anyway! he half-assed the job so he didnt hafta rewire a new harness and now ur deck doesnt work right.
