Like I said... tat setup is just wrong... I don't really know how else to explain it. The biggest issue is the splitting of the rear RCA's and then bridging them back together after the amp. The splitting cuts the signal in half, then the brigding joins it back together. It would be the same as just using a single channel.
What speakers are being used?
Rear speakers?
Midrange speakers?
Tweeters?
Subwoofer? Does the sub have dual or single voice coil(s)?
Here's what I would do in your case, give what I know at this point.
Amplifier 1 will run both the front midranges and the front tweeters. Run the front RCA preouts to the amp's inputs #1 and #2. Use a short pair of RCA cables to run the amp's channel 1 and 2 lineouts to the same amp's inputs #3 and #4. The midranges will run off that amp's output channel's 1 and 2, and the tweeters will run off that amp's output channels 3 and 4. This way, ALL the front speakers will run off the D3's front RCA outputs.
Amplifier 2 will run either just the sub or the sub and rear speakers.
If the sub is a dual voice coil model, you can bridge the second amp to two channels and use each channel for a voice coil on the sub, and use the RCA "Y" splitters to run the D3's subwoofer RCA output to all 4 of the amp's inputs. The rear speakers would be run off the D3's rear speaker output for this scenario.
If the sub is a single voice coil model, you can use channel 1 and 2 for the sub (using the D3's subwoofer RCA outputs), and channel 3 and 4 for the rear speakers (using the D3's rear speaker RCA outputs).
