D3 Bypass & Cruise Control
By ed60 · Jun 15, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,861 views
Posted Jun 15, 2008 · 23:06 UTC#1
Since I enabled bypass I have no cruise control is there anything I can do or just live with it Thanks
Posted Jun 20, 2008 · 14:53 UTC#2
Bypassing your unit has abosulutely no affect on your cruise control. I would consider other things.
Posted Jun 20, 2008 · 15:09 UTC#3
Check the fuse for the cruise control system. Also, check to make sure you have not disconnected or severed your VSS wire during the installation.
Posted Jun 20, 2008 · 23:17 UTC#4
Thanks for help I got it figured out Had e-brake & ground both hooked up!
Posted Feb 14, 2011 · 17:28 UTC#5
I am having the same problem. My cruise control no longer works. I did the bypass AFTER an installer did the install.
Maybe what is happening is that the green parking brake is actually connected to the car, and the cruise control thinks the ebrake is on?
I am not sure if the green parking wire from the D3 is just grounded, or grounded and connected... I'll have to check.
Everything else is working ok. Except that after the bypass, it no longer goes into night mode when I turn the headlights on.
