Ok. . . here goes, I have a D3 with the btb200, works great with my blackberry8830 until I get an incoming call, the unit will ring and not allow me to switch calls over, it will get hung up and keep on ringing and ringing, forcing me to have to hang up with the original call. I have reset the unit, replaced the unit, still the same issue. Any help would be appreciated ![]()
AVIC d3 and BlackBerry 8830, Blurtooth going haywire
I have the exact same setup and it all works perfectly, I'd check my settings and the BTB200 bus connections to be sure. It might very well be your phone - any ussues with call waiting when using it old school?
QX,
No issues with the phone, is there anything you had to change as far as settings on the phone?
nope, just turned on BT, the Avic D3 found my phone, entered the password on the Avic, and it worked.
I have the same exact problem with my D3 and Blackberry 8330. When call waiting goes off, there is NOOOOO way to stop it! Please help before I break something!
I called Pioneer, they said to call RIM
I called RIM, and you guessed it, they said to call Pioneer
then repeat...
I am having the exact same problem. I can't turn the ringer off without disconnecting the original call. There has got to be something that we don't have set up properly but I have gone thru both my pioneer book and my blackberry book and can't figure it out. If anyone has figured it out, please let the rest of us know.
Thanks,
Lloyd
