GPS, screen and bootup
By kouger · Jun 16, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,094 views
Posted Jun 16, 2008 · 20:51 UTC#1
Need help with the following please.
Finally got the Z2 installed and loving it except for the following problems I had today:
Drove to work, logged it in as favorite on my GPS.
Left work and when I started the car the Z2 started up but remained on the splash screen - no matter what button I hit, nothing happened. I could change volume but that was it. Hit the reset button and it finally came back. When it came back up, I was on the freeway and yet my location on the map was some other weird route no where near the freeway. It tooks some time before it "synched" to where I was.
1 - Stuck at splash screen - has this happened to anyone and what is the solution?
2 - GPS not synching - need advice
3 - Boot up - it seems to take long to boot up - what is the normal bootup time?
Please help.
Posted Jun 16, 2008 · 23:05 UTC#3
Thanks for the info - I will download the update and try it out - I did do the bypass on it but I have checked the version and it is Ver 2. The update does say to do it if you have V2.
As for the time it takes to load - well I just timed it and it seemed quicker than earlier on - perhaps because it was hanging (takes 35 seconds from the time the unit is on untill the splash screen goes away)
One last thing - is there a way to turn off the unit while the car is on?
Posted Jun 17, 2008 · 22:54 UTC#4
Finally - after wasting 3 disks, I managed to get the update loaded - will check it out tomorrow - hopefully it will be ok.
Posted Jun 17, 2008 · 22:55 UTC#5
Anyone???
Posted Jun 17, 2008 · 23:06 UTC#6
I know it sucks but no you can't.You can put a switch on the red(acc) wire to cut it off.
Posted Jun 17, 2008 · 23:07 UTC#7
Anyone???
You can turn the AV source off, and you can turn the display off. You can not turn the GPS unit off.
Posted Jun 17, 2008 · 23:20 UTC#8
Thought so, I figured out how to turn off the AV and display but was just wondering about the whole unit itself.
