Sometimes it works sometimes not so much, why so much delay?
It makes the buttons light blue when I can't use them.
N3 with 2007 maps disc, also in a area that has been there a long time.
Are you stopped?
No on the move, but I have it bypassed.
Do I have to be stopped to input an address?
It sounds like its not by-passed properly. Do you have a burnt disk?
I am having the same issue. Yes i am using a burnt nav disc
It could be the disk is bad or its not bypassed properly.How did you bypass it? Double check your by-pass and once you're positive its correct then that leaves your burnt disk as the culprit.
checked my disc and it had gotten scratched. Made a new disc and all is well.
It's amazing how such a small thing as a scratch can mess things up so much...
