NDBC20PA Back up camera
By hymis · Jun 17, 2008in General💬 10 posts👁️ 1,814 views
Posted Jun 17, 2008 · 18:19 UTC#1
I had the older back up camera and just had the NDBC20PA installed and the resolution on the new camera is not as good. Has anyone else had this issue?
Thanks.
Posted Jun 17, 2008 · 18:31 UTC#2
Yes, they are all like that
Posted Jun 17, 2008 · 18:36 UTC#3
That totally sucks! At least I'm not alone. I haven't done the setup yet, is there anything you can adjust for the picture quality? Thanks again.
Posted Jun 18, 2008 · 16:23 UTC#4
yaa i have it also and it sux
nothing in the setup that will make it better :(
what a POS
Posted Jun 18, 2008 · 19:12 UTC#5
Sorry to hijack this post for a sec, just wanted to ask - I am looking to install a camera but don't want to spend a ton of cash, any suggestions and what I should stay away from? I saw some on E-bay that were going for $24 - I think they were license plate cameras.
Posted Jun 19, 2008 · 01:28 UTC#6
It depends. If you are getting ones that is made for your deck then you are looking at way more then $24. What I mean made for your deck/model is that.
If you get a regular backup rear camera, when the car is set to reverse mode then then your avic screen will not change to the backup camera view, you will need to click the icon manually. Where as if you get the ones that are desinged for your avic then as soon as your car is in the reverse mode then the screen will change to the rear camera by default.
Best
Posted Jun 19, 2008 · 01:29 UTC#7
Not really. The specs and settings are set as default nothing really can be changed.
Best
Posted Jun 28, 2008 · 02:48 UTC#8
Where is your camera mounted, I just bought one and need to mount it on the back of a nissan frontier.
Any suggestions?
Posted Jul 01, 2008 · 15:55 UTC#9
Any suggestions?
They are desinged to go on the back plate
Posted Jul 02, 2008 · 03:41 UTC#10
Check-out www.cubbycam.com
I have one of his cameras and the quality is great! Service was also excellent.
