How to make the GPS voice not pause music
By drumasia · Jun 18, 2008in Pre-Release Archive💬 4 posts👁️ 1,705 views
Posted Jun 18, 2008 · 01:00 UTC#1
Ok... this one was bugging me for awhile, and I finally figured it out today. I saw some questions about it, but no answers/resolutions. And if it was already answered, then don't flame me. :lol: (You guys are really harsh sometimes!)
So... here's what you do:
1. Go to the Top Menu -> AV Source -> Select "Off" in the bottom right corner to turn off the music
2. Go to the Top Menu -> Settings (bottom right corner)
3. The "Mute/Input Guide" option should be available now. (First option in the 2nd row)
4. Tap to change between Mute, Att, and Normal
Mute pauses your music, Att will lower the sound of your music, Normal keeps your music at the same volume.
5. Go to the Top Menu -> AV Source -> select your source and Voila! No more annoying gaps in your music.
I also went a step further and turned the Voice all the way down, because I hate TTS. (There's so much static... WTF! Anyways... that's a complaint for another thread. hehe.)
[Edit]
Posted Jun 18, 2008 · 04:26 UTC#2
Well played sir. I just adjusted it. That makes problem number 38,562 with my unit a closed case! siiiiiiiiiiiiiiiiiiiiiiiiigh.
Posted Jun 18, 2008 · 05:01 UTC#3
How do you change it to the voice that gives you text to speech? "Samantha"? The one that says "one comma 2 miles"?
Posted Jun 18, 2008 · 05:20 UTC#4
I believe it's:
Settings -> System Settings -> Language -> Change the voice language to "Samantha TTS".
