avic d3 vss problems
By eric_c5 · Jun 18, 2008in Problems/Troubleshooting💬 12 posts👁️ 1,368 views
Posted Jun 18, 2008 · 03:44 UTC#1
I cant get my vss to work. I have it hooked up to the wire described here:
http://forums.corvetteforum.com/showthr ... ?t=1948171
It worked for a while, then after taking the stereo out to get it to fit better, I have no vss pulse when moving. I have taken the stereo out and checked the connection 3 times. I cant figure it out....is there a way to "short" a vss wire and screw it up?????
Any ideas?????
Posted Jun 18, 2008 · 04:33 UTC#2
If you shorted your VSS wire your car will have stalling problems.If you tapped the wire then I'm sure it's not getting a connection,sometimes the metal piece doesn't cut thru the insulation good and you have no contact.Have you tested the VSS wire for a signal?
Posted Jun 18, 2008 · 04:35 UTC#3
I cut the wire and connected it directly. Maybe Im crazy and it never worked and this wire isnt' a vss wire...does anybody know...the car is a 2002 corvette z06
Posted Jun 18, 2008 · 06:48 UTC#4
Is the wire green/white?
Posted Jun 18, 2008 · 23:18 UTC#5
yes
Posted Jun 19, 2008 · 01:18 UTC#6
Have you tested it to make sure you have a signal since you cut the wire?
Posted Jun 19, 2008 · 06:39 UTC#7
i dont have any way to test it....but I tapped into the wire right by the ECU and I still dont have any signal.....
Posted Jun 19, 2008 · 06:47 UTC#8
Can you get a volt meter?
Posted Jun 19, 2008 · 14:21 UTC#9
I guess I can buy one. I cant see the vss wire at the ecu being bad though....
Posted Jun 19, 2008 · 22:15 UTC#10
It shouldn't be bad but you want to verify a signal before you check anything else.
Posted Jun 25, 2008 · 20:54 UTC#11
Ok, I have a meter, but how do I test this??
I've had this wire hooked up in two places now, and I went through and looked at all of the connections....I cant figure out what is going on here.
Posted Jun 25, 2008 · 22:10 UTC#12
Ok switch the meter to volts attach the red wire to the Vss wire and the black wire to ground(anywhere on the car).Drive the car a few yards.If the meter value rises when you accelerate and lowers when you come to a stop then thats the correct wire and it's working.
