z1
By techker · Aug 18, 2006in Hacks/Mods💬 7 posts👁️ 2,163 views
Posted Aug 18, 2006 · 20:35 UTC#1
is there a way to bypass the viewing whyle driving on this?and the n3
Posted Aug 18, 2006 · 21:39 UTC#2
yes!
Posted Aug 18, 2006 · 22:03 UTC#3
yes!
Posted Aug 19, 2006 · 00:40 UTC#4
Z1-
It depends on when your unit was manufactored. Before June 06, it is able to be bypassed using a technique that involves flashing your headlights, or you can get the Ducati flasher (search the forum) and it will do so automatically.
I don't know about the N3, but I'm sure if you looked in the forum you will find the answer.
Posted Aug 19, 2006 · 00:44 UTC#5
Heres a post about bypassing the Z1 using Ducatiboys part:
http://avic411.com/forum/viewtopic.php?t=166
Again, this will only work if your unit was manufactored before June 06. If it was made after, there isn't a bypass now, although Ducati is currently working on finding a way.
Posted Aug 19, 2006 · 00:45 UTC#6
N3 - Yes. Peel back the warranty label (voiding your warranty), flip the switch under where the label used to be, and then ground the parking brake wire. Real easy. did it myself, works great :)
Posted Aug 24, 2006 · 03:49 UTC#7
i posted it for july 2006 and for earlier use a ptr-7 from periphal this are on sale on ebay
