hay all i asked my bud if i could borrow his 06 megacab because all these people keep pming me about his camera. he said sure so heres what i got
this truck is sick. avic-z2, vizualogic headrest screens (cut in, not dorp in), diamond amps, memphis speakers, kicker subs, blue led kit, bluetooth, xtra dvd player (from when he had a d3), and its lifted and custom painted. exaust sounds tough too!
so the camera is identical to the nd-bc20. on dodge trucks withe the large tailgate handle you can unbolt the inner tailgae skin and remove the handle itself. i basically cut an upside down "U" shape into the handle until the camera fit. no other camera will fit here that i know of.
its pointed so you can see the ballhitch.
the difference between the normal and the pa is this box. it has one more connection (for the retarded little 4 button switch)
so once your all installed. you will have to do a lengthy setup for this bad boy. basically you need to find a parking spot with clearly visible lines then park with the camera facing it squarely. i also hooked up a switch with diodes to the reverse input just to make programming easier.
once your parked and in setup the first step is to take a "snapshot". basically the camera records a still image for reference while your adjusting it.
from there you can adjust things like horizontal center, vertical height, rotation, witdth of the parking lines, its crazy how much you can adjust it!!
heres a bunch of pics of me going through the setup but i wont explain em too much
then after youve gone step by step you can re adjust anything you want with this menu
so basically this is what u get.
then press the "mode" button and it switches to a sweet top down view of the rear
i used speakers and dew bottles to measure the distance on the lines. the green line is 15ft from the hitch, the yellow is 7 and the red is 3 ft away. these can all be adjusted through the settings.
ive got a car to do now ill edit this laters.
