Is the speed signal input wire required? Will it function properly without it. I have never understood why this is needed. The thing is GPS! It should know my location, aprox speed without speed signal input.
Speed signal input wire.
I have no idea if this the result of no vss hookup..
I have the AVIC-Z2 with Z3 HD from a user here garrettoomey (Thanks again for the great HD and service)
I think without the wire, the accuracy of the navigation is hindered because I have passed a street when the map has me approaching it.
So, I have got the info, where to hook the wire and will see tomorrow
Also slope does not work at all.. So me thinks its an issue.
I do not know if I rehook if I will loose my modded system (hacked) or not.
Maybe someone will post it before I rip the unit out of the car and trace for the connector
Old
look up "dead reckoning"
Hooking up the VSS will not effect your bypass hack in any way.
Hyperite;
I thoughtyou where pulling me leg sir.. But I googled it and walla...
Thanks for that..
garrettoomey;
Thanks for the reply.. it all means I gotta find that connector with the wire.. I did go to Suzuki Pitstop and payed for the online manual for a month.. I now have lots of papers of printed info.
Now to do a VSS search and hookup.
(Have an GMCOL29 but it has no vss whereas the other adapter did..
Old
You may try posting in the "Vehicle Specific Wiring" forum here at Avic411.
I found it and will post my findings sir.. Spent all morning and I have conquered it!!!
Old
I took the plunge and did not hood it up. At times it is inacurate, however it does correct itself quite often. I believe it to be a very minor thing. I would not recommend hooking up the wire if you have to do a lot of digging to get to it, like me.
Thanks to all for your input
