AVIC D3 not turning on HELP 911!!!!!
By Cesarr2006 · Jun 21, 2008in Problems/Troubleshooting💬 9 posts👁️ 4,574 views
Posted Jun 21, 2008 · 19:35 UTC#1
Ok i bought my D3 a few months ago it was working fine i did the bypass and everything was going great. Yesterday i tried to search for a nearby starbucks and noticed all my search buttons were not working. I couldnt select any of them. I thought maybe there was something wrong with the bypass so opened it up and was checking the wiring nothing disconnected or anything. I decided to check it later and as i put it back into its place it just shut off no sound no lights nothing what so ever I need help please!!!!
Posted Jun 21, 2008 · 20:07 UTC#2
Either you blew the radio fuse or knocked a wire loose.
Posted Jun 21, 2008 · 20:07 UTC#3
did you have to force it bak in place? it sounds like a pinched wire. take it out, check your connections, make sure its all good and check the fuse on the bak of the unit too.
Posted Jun 22, 2008 · 09:55 UTC#4
Yeah i did i kinda forced it in there. I checked the fuse in the back and one that controls the stereo in the fuse box below and they were both ok. I read yesterday to check all the fuses and i havent done that yet. What did you mean by a pinched wire? do you think something could have happened to it internally? I didnt bang it in or anything not i just gave it a little push.
Posted Jun 22, 2008 · 16:02 UTC#5
First thing you need to do is get a circuit tester and verify that power is getting to your D3 and check the fuse. It sounds to me that you either blew a fuse or disconnected a cable. Let me know the results. If still you have not figured out the problem, let me know and we will try something else.
Posted Jun 22, 2008 · 17:03 UTC#6
a pinched wire is where it gets caught between something and either causes a break in the wire or stops the current completely. it happened to me back when i did my first stereo install. one example would be if your yellow wire (constant+) or your red wire (12vpower) got pinched against a metal surface and is causing a short. check every wire out.
Posted Jun 25, 2008 · 00:59 UTC#7
THANKS FOR ALL THE HELP!!!!!!! It was just a fuse thank god i was thinking i had to replace it all....but thanks for all the helpto all u guys
Posted Jun 25, 2008 · 01:22 UTC#8
worst feeling in the world.....go in such a panic to only find out it was a blown fuse. well glad to hear everything turned out good.
Posted Jun 25, 2008 · 02:47 UTC#9
Glad to hear you are good to go. We all knew it was something along those lines.
