Ok, this is for the XL-7, but as if you did'nt know, it is like the Chevy Equinox, Pontiac Torrent and some other GM SUV's
Ok all... Just spent a good part of this morning hunting down this famous VSS wire for navigation units.
After following every possible path it can be found in the car at..
Behind the Driver side kick panel.. remove the panel (the one on the left under the dash).
Find 2 connectors.. a smaller Yellow and a much Larger Gray connector (has a white latch to make it dis-connect).
The gray connector has a Green/White wire and is in the corner of the plug unit (pin 17 if you fine it). But the hard part is that if you do not have factory NAVIGATION (If you have the manufactures navigation a plug with the lonely Green/White wire will be connected to the head unit.) installed by manufacture, you will not have the luxury to get to the wire..So... You must unplug that top connector and pop the bottom one away from the car so you can get to the Green/White wire to be able to splice to it..
That kick panel is clipped to the floor and 2 are by the front edge.
I hope this helps for your navigation needs.
Old
