Phone Book Transfer from Smarthphone WM6 Std
By blindmind3 · Jun 22, 2008in Hacks/Mods💬 24 posts👁️ 5,959 views
Posted Jun 22, 2008 · 21:56 UTC#1
I was having issues getting my phonebook to transfer until I found this http://www.jetwaremobile.com/
I was finally able to upload the contacts from my Verizon SMT5800 Smartphone running Windows Mobile 6 Standard. And it uploaded them all in one shot.
Just wanted to pass it along. 8)
Posted Jun 23, 2008 · 02:16 UTC#2
i was real happy to have my Verizon Wireless XV6800 connect and upload the phone book flawlessly. i had my concerns because of the issues the btb-200 had with windows mobile 6 phones.
Posted Jun 23, 2008 · 03:09 UTC#3
I have the Motorola Q9H running Windows Mobile 6, and it took a few times, including Windows crashing on the unit, but eventually it did transfer my phone book without any special software.
Posted Jun 24, 2008 · 17:43 UTC#4
Has anyone had any success with the palm os based smartphones? I'm on the verge of buying this unit however, the only thing holding me back is the bluetooth, as I do not want to loose that functionality. Granted they fix all the other flaws....
Posted Jun 24, 2008 · 18:47 UTC#5
For those that have done it, I'm looking for a step by step PhoneBook/Contact transfer help.
I've exhausted my limited knowledge and tech abilities, but still cannot get transfer done. The phone is paired via Bluetooth, so call can be placed and recieved, but no contacts.
HTC 6800 (Sprint Mogul) Windows Mobile 6
Posted Jun 24, 2008 · 20:48 UTC#6
I have the HTC Dash from tmobile (wm5 i believe *edit - nope wm6). I am pretty sure I had to edit the bluetooth profile for the avic on my phone to enable the serial port before it would transfer.
When you go into the transfer phone book screen on the avic, "ok" through the stupid beam prompts to the actual transfer screen. It should be the one with the cancel button. Just don't press cancel. I left mine to do its thing for about 5 minutes and it transferred the contacts and all was well.
Good luck.
Posted Jun 24, 2008 · 21:45 UTC#7
still not working what do I do with the phone, start/run any applications? :x
Posted Jun 24, 2008 · 22:01 UTC#8
Do you have a "beam" option you can enable on your connections?
Posted Jun 24, 2008 · 22:12 UTC#9
Beam:
Receive all incoming beams. CHECKED.
Bluetooth settings:
Devices - Pioneer Navi - Serial Port & Hands Free CHECHED
Mode - Turn on Bluetooth - Make this device visible to other devices CHECKED
COM Ports - None at this time
Security - Authentication (Passkey) required NOT CHECKED
Posted Jun 24, 2008 · 22:21 UTC#10
The only other thing I can think of would be to go into your contacts on the phone and select a contact, then "menu" - "send contact" - "beam" (if you have that option).
I tried that early on... didn't seem to do anything. Then after just letting the Avic do its thing on the transfer page (the one with the cancle button), all my contacts were there, not just the one I had previously tried to "beam."
Could also be your cell provider has limited your devices capabilities. those bastards are notorious for that kind of stuff.
Posted Jun 25, 2008 · 01:28 UTC#11
I used jetware after trying numerous methods and it worked!!! Definitely, recommend jetware.
Posted Jun 25, 2008 · 01:38 UTC#12
lsdlls07:
But what are the setting for the software, or are you just installing it.. done?
Posted Jun 26, 2008 · 03:00 UTC#13
Anyone else having issues, or have Sprint phones that have got this to work? I'm still trying different methods, but nothing is working. :evil:
Posted Jun 26, 2008 · 13:13 UTC#14
I installed it with default settings. Then I chose the "phone book" setting and then the "send contacts" setting with all defaults. On the AVIC, go to the phone book transfer settings and keep clicking OK until you get to the "loading data..." screen. There should only be a cancel button at this point. You need to send the contacts from your phone at the "loading" screen.
This is all off the top of my head. If this doesn't help, I'll try to give you a step by step when I get back from vacation.
Posted Jun 26, 2008 · 20:49 UTC#15
:) Got phone book transferred. Now what. I have multiple listed names for all contacts (even ones with only one phone number??), voice (name) calling doen't work for any of my contacts. So the point was :?: Where do we go from here.
Posted Jul 10, 2008 · 02:44 UTC#16
I had multiple contacts for each name too...I'm not sure if in the "send as V card" will eliminate the extra names.
Posted Jul 10, 2008 · 11:39 UTC#17
The first time I tried it, it worked perfect...only one of each contact. I decided to clean up my address book and resync. Since then, it has been importing 2 of each for me as well and the voice dialing won't work for them either.
Posted Jul 14, 2008 · 02:10 UTC#18
I have a Motorola Q9h and it will transfer some of my contacts but not all of them, anyone else running into this?
Posted Jul 20, 2008 · 22:56 UTC#19
Same problem. I have roughly 1/3 of my contacts transfer over, but some don't. Also, I'll have 3 names for someone whom I only have two numbers for on the stereo's contact list. Hallp. Haha.
Posted Jul 23, 2008 · 17:28 UTC#20
after applying the firmware update, I erased my phonebook and performed another transfer. This time it worked perfectly. Only one contact for each number and the voice recognition is working!!
I still had to use the 3rd party app though to get the numbers over
just an fyi :)
Posted Jul 23, 2008 · 18:58 UTC#21
i installed jetware into my xv6700, but now am clueless what to do next. Can someone post a brief tutorial on the steps? Thanks.
Posted Jul 28, 2008 · 05:13 UTC#22
It's a shame this doesn't work with my Blackjack. Oh iPhone in January.
Posted Aug 21, 2008 · 17:58 UTC#23
Hope it works with my AT&T Tilt...
Posted Sep 08, 2008 · 15:29 UTC#24
My palm treo 800w paired up perfectly running windows 6.1. I was a little skeptical about buying the radio because of the the problems I had with my mogul and treo on the btb-200. Anyone having a problem with the mogul try updating it to windows 6.1 then it works nicely with the bluetooth.
