2006/2007 Lincoln zephyr/mkz?
By HeavenSoldier · Aug 19, 2006in General💬 8 posts👁️ 1,857 views
Posted Aug 19, 2006 · 16:32 UTC#1
Anyone got the avic z1 to fit in the zephyr? Or do you think it will fit good and work?
Here is a picture of the dash in the Lincoln MKZ (renamed to Mkz instead of zephyr for 2007).
Posted Aug 20, 2006 · 03:00 UTC#2
i worked on a 2006 lincoln zephyr n it is possible to put a z1 in it. u just gotta find the right kit. the 1 i worked on had a thx certified system wit factory nav, it was pretty bad-ass. the weird thing is, wen i got behind the radio, it had a chrysler antenna (cr-10) and a chrysler wire harness (80-6502). but if u hav the kit it shouldn't b a problem itz iso-mounted.
Posted Aug 20, 2006 · 03:44 UTC#3
ricerocket21x said:
i worked on a 2006 lincoln zephyr n it is possible to put a z1 in it. u just gotta find the right kit. the 1 i worked on had a thx certified system wit factory nav, it was pretty bad-ass. the weird thing is, wen i got behind the radio, it had a chrysler antenna (cr-10) and a chrysler wire harness (80-6502). but if u hav the kit it shouldn't ba problem itz iso-mounted.
Okay cool I plan on buying this pre-paid installation thing http://www.crutchfield.com/S-mcMwM790a7 ... =597421000 whenever I do get the avic z1, maybe some time next year or in the fall. So I hope the installer knows what to do because I don't want my car damaged. Did the avic z1 look good in the zephyr? Thanks again, God Bless.
Posted Aug 20, 2006 · 04:44 UTC#4
Yes it looks stock. As mentioned before the harness and antenna adaptorare chrysler parts. The kit, I'll have to check work tomorrow for the part number but it's a ord double din kit. Actually some of the guys here have probably used it for the newer f150s and such.
Posted Aug 21, 2006 · 04:26 UTC#5
Oh okay cool, so should I still do the pre-paid installation thing from crutchfield to do a professional installation, or should I take it to somewhere like circuit city and they'll do a good job? Thanks and God Bless.
Posted Aug 21, 2006 · 15:34 UTC#6
THe part # is 99-5802. As for taking it to be installed, might want to talk to whomever you're looking to have put it in first and make sure that they're going to do all that should be done. Such as hooking up the vss, reverse, and illumination. You can also see if they do the bypass for you. I know circuit and best buy cannot do that though.
Posted Aug 21, 2006 · 18:20 UTC#7
Okay I really don't need the bypass, I may get it later in the year (z1). But I want everything installed to get a great gps signal. I also want the navtraffic and back up camera if it's possible to install that.
Posted Aug 22, 2006 · 00:18 UTC#8
Anything's possible for the right price. To be serious though neither of the things are that big a deal to put in at the same time.
